(#2726)
chrisdfv chrisdfv is offline
Car: 2008 335i
Default 07-16-2016, 12:38 PM
Needs some help
Default 07-16-2016, 01:18 PM
Logs go in the support forum.
za_1m za_1m is offline
Car: 1M
Default 07-16-2016, 01:38 PM
Need some help please as I can't seem to find related information...
My car had the older DME version IKCOS, as part of my initial MHD setup, I backed up the ECU with saved my stock IKCOS DME file, I then loaded the JB IKMOS BEF, which I'm told would have updated my DME to IKMOS.
I'm wanting a custom tune, but I was told that I need my stock bin to be updated to IKMOS, which I though would have happened once I flashed the IKMOS BEF, so flashed car back to stock thinking that the DME would have updated to IKMOS, it flashed back to stock perfectly now I can't seem to saved a copy of my BIN, I get an ECU exception error...any idea's?
pepper135i pepper135i is offline
Car: 135
Default 07-16-2016, 05:03 PM
Originally Posted by MHD
Yep, just make sure you have MHD 1.40, check the flash options and rewrite.
The latest version is more progressive and thus the interpolated timing is a bit less reduced. I'll need to add a new "harder" setting.
To anyone willing to help testing the map 0 switch, you can first test the map 0 auto switch feature by plugging in MHD and do "read codes". It will send the same message to the DME that the JB4 notice and use to switch to map 0. Or MHD store, or anything that requires a connection to the DME in MHD like reset adaptations.
I am glad you're testing this automatic map 0 switch I suggested 2 weeks ago per email. You're right, adapting some settings to be modified on the fly is definitely on our list of things to develop.
I uploaded the latest jb4 update last week and have since flashed my ecu a good 10-15 times .. New update works flawlessly ! You get two flashes and it drops you to map 0 automatically . On a side note I have opted into beta testing via Google store but was wondering if this applies to BEF users ?
qgshadow qgshadow is offline
Car: BMW E82 2008
Default 07-17-2016, 09:56 AM
I just flashed the ECU with the JB4 backend and have JB4 + DCI.
What's the next big upgrade i could go to gain most power?
I still have stock turbos and was wondering what could be my next upgrade for maximum power.
And do i have to change anything else in JB4 settings except for 4-2 when flashing the ECU?
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 07-17-2016, 03:26 PM
Really depends on what you mean by "max power".... You can change to a large single turbo,down ***** , inlets, meth or port injection, custom tune, custom tune and the list goes on.
Much of the decision making revolves around what your intended purpose is with the car. Lots of good options to have fun with.
6MT, JB4, DCI, BMS Pump BEF
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-17-2016, 03:36 PM
+1
but in general intercooler, OCC, oil vale and ********* a must with intake valve cleaning,
Make sure you frequently change oil and plugs
After that depend on your power goals, maybe meth, E85, inlets and outlets...... And list goes on
Oryx's Avatar
Car: 2010 535xi
Default 07-17-2016, 03:43 PM
Don't know how I forgot e85!!
UnoDos UnoDos is offline
Car: 335RBi
Default 07-18-2016, 12:57 AM
Hi guys!
Do you know if I can use the BT cable to do the backend flash with MHD??? I'm trying to flash my car but de BB software doesn´t work, and I feel like I wasted 179 $....
Thanks.
Rushan's Avatar
Car: 335i E92 2009
Default 07-18-2016, 12:09 PM
Originally Posted by UnoDos
Hi guys!
Thanks.
No you can't use the BT cable with MHD
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 07-19-2016, 11:48 AM
As seen per email - remove your backup file before flashing back to stock to force an update, rather than reflash your old software again.
Beta channel is mostly used for MHD maps testing.
Hi guys!
Thanks.
Can't your return it?
ArsE92 ArsE92 is offline
Car: 2007 E92 335i AT
Default 07-19-2016, 11:46 PM
Hi Folks
Apologies if this has been covered but I can't find much talk of it.
I have a 2007 335i with a JB4 ISO running the MHD back end flash (1-6-16). I have terrible jerkiness which feels like fuelling being cut completely when changing up at anything greater than 90% throttle. My car is an AT and I always use 99RON fuel in the UK. I have the Alpina gearbox flash.
Should I try the desensitise knock sensor option? I'm a bit concerned about the potential engine damage. How likely is that?
Thanks in advance!
Car: 335RBi
Default 07-20-2016, 02:04 AM
Don't think so. I guess I'll go with MHD flash. Thanks mate.
Grounded Grounded is offline
Car: N54
Default 07-22-2016, 05:47 AM
Originally Posted by ArsE92
Hi Folks
Thanks in advance!
Remove the jb4. If the problem goes away try a mhd flash only.
Oryx's Avatar
Car: 2010 535xi
Default 07-22-2016, 03:41 PM
Wouldn't you want to just understand the root cause and address? Probably a setting adjustment.
"A poor craftsman blames his tools"
Car: N54
Default 07-22-2016, 09:11 PM
yes, but that can take a long time. You may still not even figure it out. Your quote makes no sense in this situation. We are discussing modifying cars.
Oryx's Avatar
Car: 2010 535xi
Default 07-23-2016, 05:18 AM
I wasn't personally attacking you, just referring to the situation.
JB4 and MHD are tools used to tune. The application of their capabilities to achieve a desired tune sure seems like a tool to me. An OTS tune doesn't always perform the same for every car and parameters may need to be adjusted. The same goes for both products. In many cases the use of both together can achieve the best results.
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 07-23-2016, 09:19 AM
How I can change setting like"bug shift" etc... In bef. I have bef race for jb4 for now.
Thank
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL **|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
AdamHarbour AdamHarbour is offline
Car: N54 135i
Default 07-23-2016, 09:40 AM
Anyway to make the exhaust burble work when stationary??
willyjoe willyjoe is offline
Car: E93
Default 07-23-2016, 10:43 AM
Ok, so my buddy was flashing his car with a backend flash and the tablet got a battery overheat warning halfway thru and killed the flash. now the car has nothing. We cant even get the key out. Battery has a full charge. I'm lost. any suggestions?
08_335i 08_335i is offline
Car: 2008 335i
Default 07-23-2016, 11:15 AM
Restart the flash, MHD should give a full reflash option.
Car: BMW 1M Coupe
Default 07-24-2016, 10:37 AM
Would like to know too
Car: 2008 335i
Default 07-24-2016, 12:00 PM
Put it in gear, take off real quick then slam on the brakes. Burble while stationary.
MDMA 135i MDMA 135i is offline
Car: BMW 135i
Default 07-24-2016, 05:44 PM
Please help, last month i was driving on the freeway and few minutes after some hard driving i try to accelerate in the 4nd gear and got reduced engine power and mhd read 30FF - Low Boost Pressure. I also think that i heard some strange noise like something was broken..
Mhd stg 1+,*********,without intercooler
Car has a boost but there is no power any more :/
What can be a problem that there is boost but no power. Turbos also changed sound but not significant.
This is log before failure
http://***********/u/bmw135in54/log-1...10-11-12-13-24
Log after failure
http://***********/u/bmw135in54/log-1...=0&data=4-6-24
here i have timing correction but i changed my old original bmw spark plugs for new bosch plugs..
Sorry on my bad english and i hope that is only boost leak :/
i uses mhd only for 700-800km
enrita's Avatar
enrita enrita is offline
Default 07-25-2016, 02:56 AM
Check the charge pipe
