(#26)
Default 01-20-2015, 01:28 PM
Originally Posted by gunda
Hey Terry,
What if we used this as direct port injection for water/meth instead of for fueling? Something like this:
http://www.e90post.com/forums/showthread.php?t=947629
Would it be a good idea/upgrade from the chargepipe/meth bung setup? It should ensure that all cylinders are recieving an equal amount of the water/meth.
At this time if using the PI we suggest removing any meth kit & capping the bungs.
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 01-20-2015, 01:45 PM
Originally Posted by cebrailbakan
Excellent question !
Any idea please
The car has the following steps, jb4 , full bolt ons, Rb, forged internals and vac cylinder head stage 1 and my trouble avg ign retard (9.1)
. Thanks in advance.
Any idea please ?
Do more with less !
The Leopard's Avatar
The Leopard The Leopard is offline
Car: E92
Default 01-20-2015, 01:48 PM
Any idea please
The benefit is not having to mix fuel, not running meth, cooler combustion, and perhaps more knock resistance. The built motor part won't matter here.
TS N54
Car: BMW E90 335XI
Default 01-20-2015, 02:00 PM
Are you sure you understood the question ? I can't see any insisting phrase for my built engine ? Just wanted to learn if it is a good way for better fueling!
Do more with less !
Car: E92
Default 01-20-2015, 02:03 PM
I'm sorry, your English is broken and not in complete sentences (with no direct question posed), so we have to guess at what you're asking.
TS N54
Car: BMW E90 335XI
Default 01-20-2015, 02:22 PM
my English is better than your Turkish ,if you look in a good intention , saying get out of here instead, you'll see language doesn't make a sense that much. Thanks for your respect!
Do more with less !
Car: E92
Default 01-20-2015, 02:24 PM
^ Q.E.D.
We are just trying to be helpful. You are hard to understand.
TS N54
Car: BMW E90 335XI
Default 01-20-2015, 02:33 PM
Originally Posted by The Leopard
^ Q.E.D.
Ok I am hard to understand. Thank you.
Do more with less !
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 01-20-2015, 03:14 PM
Terry, doesnt the aic4 run off two maps? tach and map? could it run off tach alone? and at what boost would you prefer it to go to since 26 isnt enough?
Default 01-20-2015, 03:32 PM
It has one map for each MOSFET but as implemented we just copy map 1 over to map 2. Only one map is needed for this application as we run the same fueling in bank 1 as we do in bank 2.
In a perfect world the AIC4H would take in a 0-5v input and let you map on that. 4.5v on the 3.5 bar sensor goes up to 36psi.
erichale's Avatar
Car: 335i coupe
Default 01-20-2015, 03:55 PM
ok thanx terry. ill talk to mark at split second and see if he can customize the aic6 to your preffered specs. i had one made for my xmas gift but someone stole it from my door after it was delivered.
Car: E92
Default 01-20-2015, 04:33 PM
Terry, which AIC4H do we need. The AIC1-G4H or AIC1-A4H?
TS N54
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 01-21-2015, 11:08 AM
very interested. When would the complete kit available? DIY?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
TT-Tom TT-Tom is offline
Car: C.S.B.
Default 01-21-2015, 11:41 AM
Terry/Steve are you planning on offering an upgraded fuel line and or a return to support the additional flow?
bmsportzn135i's Avatar
Default 01-21-2015, 11:46 AM
Terry, I can understand that we would no longer need the meth. But with running the PI would we be able to start pushing higher whp on pump fuel alone? Or would you suggest still running a ethanol mix? I would love to achieve similar numbers on straight pump fuel.
537.75HP 540.63TQ
Default 01-21-2015, 12:26 PM
Not going to happen on pump gas unless you do 8:1 compression pistons, etc. If you can't use E85 there is no reason to add PI IMHO unless your system is maxing out on race gas.
Default 01-21-2015, 12:27 PM
That's the thing. I don't want to waste their or my time with it as we won't be using or suggesting it long term. The off the shelf one works. Use that until something better is available. Then sell it down the road.
n54 power's Avatar
n54 power n54 power is offline
Default 01-21-2015, 02:21 PM
Hi terry
I'm waiting for this kit, when ready,I want to buy...
:b urnrubber:
Default 01-21-2015, 09:17 PM
I've got the rails & injectors but making the harnesses is a pita. I'll make a few myself but then I'll need to send the supplies over to our harness manufacturer which will probably take a few weeks.
Default 01-22-2015, 10:48 PM
Originally Posted by FastGti69
Ohhh, I think I'm missing some wires LOL.
I think so too. I was like WTF?
Default 01-26-2015, 12:00 PM
Injectors are in.
Car: E92
Default 01-26-2015, 12:05 PM
Can't wait. I just used the last of my meth drum this weekend and do not plan on buying another.
TS N54
n54 power's Avatar
Default 01-26-2015, 12:43 PM
Injectors are in.
i wait the kit ..
congratulate terry
andydna15 andydna15 is offline
Default 01-26-2015, 01:22 PM
Can I run this kit without a jb4?
Default 01-26-2015, 01:44 PM
Sure but the free maps included are tuned for use with a JB4. So you'd have to develop and tweak your own maps.
