(#6176)
chrisinfla chrisinfla is offline
Default 02-01-2013, 12:42 PM
Originally Posted by rudypoochris
Did you try 16B with high lagfix? I got mine at 80 and its sweet. 15C was interesting, but burned a lot of fuel for me. I prefer the drive characteristic of 16B too. To get the response out of 15C that I wanted required settings that made the gas pedal require only like 10% input to be accelerating still at 130mph lol.
yah, 16b with a 70lagfix. Left everything else on autotune b/c I had the best result with it on the G4 using E85. What does the pid gain setting do? Worth adjusting just to see how it feels or just leave it alone?
mzman mzman is offline
Car: 135i, 944T, M3, MRoad, Miata
Default 02-01-2013, 01:42 PM
Those settings are?
Current Euros:
'08 135i AW/CR -- FBO, E35, WW Meth 40/60 M/W
'95 M3 Blk/Blk -- Cosmos V2 intake, Borla exhaust, 3.5in MAF, 24# Inj., LTW FW, Turner chip, Euro Brakes, Koni S/A's, H&R Sport springs
'88 944 Turbo S SRose/Tan -- Too many mods - 401rwhp/429ftlb
'99 M Roadster AW/Blk -- Stock
Past Euros:
'87 944S GR/Blk -- Exhaust, Intake, throttle cam, coil-overs
rudypoochris rudypoochris is offline
Default 02-02-2013, 04:10 PM
Originally Posted by mzman
Those settings are?
I don't remember. The 15 ISO was the funky one that let you set FUA and lagfix for some combined throttle and lagfix thing. It was nice and smooth, but to get good throttle response I felt I had to do a combination of the two settings that resulted in boosting with very little pedal input. You could set it up to take really little pedal to go pretty dang fast. I didn't not like it, it was just weird and bad for the fuel economy. 16 is a lot better.
2008 335i Coupe 6MT
JB4G5, DCI, Wagner FMIC
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 02-03-2013, 08:06 AM
anyone???
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
ChrisCote ChrisCote is offline
Default 02-04-2013, 01:07 AM
Was rear ended tonight, just a scratch, Should I remove my tune before taking it into the dealership? Thought I woild ask.
Default 02-04-2013, 02:11 AM
At a minimum I would set it to map 0, if you really want to error on the safe side...remove it. What other mods do you have?
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 02-04-2013, 07:34 AM
Well, depends on how easy you can remove them. Do you need to take it to the dealership for a bodywork?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
Milwaukee135's Avatar
Milwaukee135 Milwaukee135 is offline
Car: 2008 135i
Default 02-04-2013, 08:33 AM
Originally Posted by erwan35
anyone???
Since I do not have meth injection, I run Map 5 in all conditions.
Map 5 will adjust for the octane you have, and I can tell you that it is very effective. I often switch between E85/93 octane mix and just 93 octane and the boost, advance etc adjust perfectly.
Map 5 starts at map 2 and adjusts up or down depending on how the engine reacts to its inputs. I suspect the main control are the knock sensors.
On 93 octane I tend to get max boost of about 14.5 psi, which is map 2. On 35 percent E85, I can hit 18+ psi -- but I limit the boost to a lower value since I am not racing. I live in Milwaukee though, and the hottest days here do not compete with your hot days.
I've been running this way over 10k miles and had no negative effects. I recently removed the spark plugs and they were wearing perfectly.
So even for race gas, Map 5 should be better than map 2 -- assuming you want the extra power from the higher octane.
This has been my experience. Your results may vary.
Note that when you switch octane levels you have to switch out of map 5 and then back in to reset the controls. Based on the JB4 controls I've seen, this means switch out of map 5, turn off the control menu, then back to the control menu and back into map 5.
EDIT: you also need to run WOT a couple times for a few seconds to let the JB4 adjust.
Tuning Obsessed Central Oregon Engineer
08 E82 N54 (bimmerboost flash tuned by me)
suii suii is offline
Car: 535i
Default 02-04-2013, 11:18 AM
Just updated to 16b from 13 and loving the update.
Default 02-05-2013, 06:28 AM
Oops, I misread your first post. I thought you said you tweaked several settings in 16B to get the punch of 15C back. That's what I was interested in, I also messed with that weird split on 15C.
Once I was able to get a clean install of 16B I much prefer it.
Current Euros:
Past Euros:
geterdone's Avatar
geterdone geterdone is offline
Boosted
Car: 2007 335is E90
Default 02-05-2013, 09:52 PM
100k and luckily no rattles at all. Car had 68k when purchased so it is possible they could have been replaced. BMW pulled the service history and nothing is there???
2007 335is 100K/ JB4 G5 ISO/ Burger DCI/ No ***** VRSF(Great) **'s/ Alufelgen's/ Custom Piping. 12.1 at 118.5
geterdone's Avatar
Boosted
Car: 2007 335is E90
Default 02-05-2013, 09:56 PM
Mind I ask what changes you made?
dr.george dr.george is offline
Car: 135i 6 speed MT
Default 02-06-2013, 04:51 AM
I just updated my 135 from JB3 pinout to JB4 G5 ISO firmware, running map 2, I must say it pulls much stronger now!! Power much more linear than before!
Just a little spark like noise when getting off the throttle, normal?
erwan35's Avatar
Car: bmw 335i e92
Thumbs up Nice! - 02-06-2013, 11:09 AM
THANKS!!! Will do mate!!
Bobdudeman1988's Avatar
Bobdudeman1988 Bobdudeman1988 is offline
Car: 07 E90 335i
Default 02-06-2013, 11:13 AM
What's or how's the progress on making the board less likely to melt the case? Waiting to order g5 till that's fixed
erwan35's Avatar
Car: bmw 335i e92
Default 02-06-2013, 11:17 AM
so everytime i blend higher octane fuels i had to reset which is speedo 1/tach 7?
erwan35's Avatar
Car: bmw 335i e92
Default 02-06-2013, 11:29 AM
oh and what do u mean by map 5 starts at map2??
aoschadlin's Avatar
Car: 535i
Default 02-06-2013, 02:49 PM
I think he means that Map 5 boost levels start at the Map 2 level and adjust from there.
Stucks Stucks is offline
Default 02-06-2013, 09:52 PM
what settings? lol
Current: 2008 e92 335i coupe.
Default 02-06-2013, 10:11 PM
No updates there. Heard of a few occurrences of the box deforming out of many hundreds of units in use so suggested those who have the deformation remove the enclosure. We've been working on getting the enclosure made in higher temperature plastic but so far has been nothing but headaches and delays.
Car: 07 E90 335i
Default 02-06-2013, 10:47 PM
Is there any part of the board that specificly gets hot..? heatsinks maybe?
erwan35's Avatar
Car: bmw 335i e92
Default 02-07-2013, 05:12 AM
Right ok. So to reset do i hv to go on 1/7 all da time?
b1aze's Avatar
b1aze b1aze is offline
135i is in my sights...
Car: 2011 WRX STI
Default 02-07-2013, 06:53 AM
No, go Speedo 0 tach 0 to go back to stock. That is, as far as i know, how you can reset the Map5 adaptation values.
Car: 2008 135i
Default 02-07-2013, 07:13 AM
To reset you can pick any other map ... say map 4. But you have to switch out of speedo '0' to make the map take effect. So I just leave the menu and come back. You could also got to speedo '1' and back to '0'.
Car: 2008 135i
Default 02-07-2013, 07:19 AM
You have to 'reset' every time, which is done by changing map. The reset for 1,7 is about the dials on the dash.
Also, by map 2, I mean that the boost levels, timing etc are set at map 2 when you first switch into map 5 from another map. Then based on the knock sensors and other DME/engine responses the JB4 adjusts boost, timing etc to match the octane. It will go up or down depending on how the engine responds.
With E85 it jumps quickly to 17-18 psi boost. with 93 octane it stays roughly at map 2. I have not tried lower octane in a while, but it will reduce boost closer to map 1 if you cannot sustain map 2 due to the fuel you have.
Once it gets settled, it stops adjusting though -- which is why the need for the reset.
Whenever I get gas -- even if I do not change octane -- I do a map switch out of map 5 and then back. The main point about "leaving the menu" is that the JB4 does not do the change unless you switch the speedo side. Just changing the tach to 4 and back to 5 without changing the speedo does not work.
I hope this helps.
