importroller importroller is offline
Car: 2016 Q50 3.0t
Default Car feels slower - 09-07-2020, 05:38 PM
not sure if it's just because of the hot weather, or if the turbo system just can't do its thing for some other reason.
24VALVES FROM HELL's Avatar
24VALVES FROM HELL 24VALVES FROM HELL is offline
Car: 2017 Q60
Default 09-09-2020, 09:54 AM
Both logs have super lean AFRS across the power band. Try another map. I would highly recommend to keep the afrs between 11.5 to 12.5 if running 93 octane.
Default 09-09-2020, 02:49 PM
What fuel, mods, etc?
Car: 2016 Q50 3.0t
Default 09-25-2020, 12:56 PM
mods are JB4 with Fuel wires and EWG.
Megan LDP
and 2.5" catback
BMS HeatX
Turbosmart BOV
and i'm running 91 with some E85 mixed in.
I've been noticing the car sometimes is leaning itself out when I check the logs. I attached two more logs in Map6 from yesterday. I'm gonna try a Map 5 pull today to compare
Car: 2016 Q50 3.0t
Default 09-25-2020, 01:46 PM
heres a map 6 and 5 log from today. I noticed it looks like map 5 isn't doing anything. the boost levels are the same as the ECU psi.
