Rebeka Rebeka is offline
Car: Baleno
Default Cobb 1+ possible misfire - logs attached - 08-25-2021, 07:43 AM
Hello, I just updated my cobb tune to the stage 1+ (supporting mods in place) and logged my initial test pulls. Unfortunately everything was not ok. On the second time going to wide open throttle I felt what appeared to be some misfires a few moments in the the pull. The car jerked somewhat like hitting a rev limiter.
The first was in a lower gear and potentially not a good example. mobdro kodi
I am thinking I am lucky the car is fine. Unfortunately I do not see a clear problem. I am not that familiar with logs for this car and was wondering if someone with a more trained eye would take a look.
I am running California's lame gas so I am using the "drive" tune.
I will likely drop the tune to stage 1 drive (without the + even though I have the larger FMIC) and log again sometime soon; with the though that assumedly more conservative boost and timing will help. If anyone want to suggest different logging fields please feel free.
Thanks for your time and consideration.
