cfou335's Avatar
cfou335 cfou335 is offline
Car: 2015 BMW 335 xdrive
Default 05-21-2021, 12:02 PM
Map 2 is an additive map...you're not overboosting. Map 5 looks fine but your WGDC is maxed out....so either not much left in the turbo or you have a boost leak.
Okay I will double check everything The only thing that I was swapped out was the dp and the valve cover also the valve cover gasket. Do you know offhand how much the stock turbo will put out before it's fixed out is it like around 20 or 21?
