Boland01's Avatar
Boland01 Boland01 is offline
Car: 535ix
Default 12-31-2018, 08:36 AM
You will remove the brake air ducts for this to fit.
It sits behind fog lights, you're still good with that.
It's about a 1-2 hour install. I'm working on the guide right now.
Here's a little recap of whats done for those who can visualize. Really easy!
Pull off driver side wheel.
Pull off bottom cover, and driver wheel well.
Pull out radiator fan.
Pull out stock AT cooler.
Cap coolant hoses with provided billet pieces. PNP
Attach two hoses to OEM AT trans oil lines.
Remove brake air duct (Depending on 135i or 335i)
Attach bracket and oil cooler to frame with provided billet pieces. (No drilling required)
Tighten hoses and bracket.
Reinstall wheel well and under cover.
Done!
Payam- I would add to your instructions to make sure the transmission is at the correct fluid level per the ZF procedure. Our transmissions are pretty sensitive to this. I'm sure this will be a great product.
