(#3000)
Default 10-10-2019, 10:31 AM
Originally Posted by Eracer76
So I finally got my single turbo up and running and got some 3rd gear logs of Map 1 (safety map) on a 14psi WG spring setup... If someone here could take a quick look at them for me, I'd greatly appreciate it!
Its a Z4 35i w/Speedtech 6266 gen2 and all supporting mods and running 100% E85
Fuel trims are basically maxed out, you can try raising OL to 80 to see if that helps. You might get a code, if so lower back to 70.
Do you have PI?
Also, enable 6 cylinder timing in the user adjustments tab.
