Default 09-05-2019, 11:36 PM
Looked at the map 5 logs- look “ok”
Tbh your probably not feeling “much” because you aren’t targeting much boost.
I’d load the bef, get the LPFP installed & bump up to e50/60
The stock Turbos are small, so low end, and mid range is where they shine- you just need to turn things up.
