(#2976)
ferocious's Avatar
ferocious ferocious is offline
Car: 335i N54 2008
Default 04-28-2019, 12:53 AM
Originally Posted by DeepEddy
So I have been sticking with map 2 and a E60 +/- mix. The plan was and is to get PI and get some more boost. Unfortunately I had a injector go bad, so I finally took a good look at mine and I had four index 5 and two index 9, so I replaced all six with new index 12. Along with a few other unexpected expenses PI is delayed for a few months. I still would like to get a bit more then map 2 has to offer so I been looking at my current setup. I am running meth with a single CM10 in the charge pipe. Would map 8 be a better option for me ? Is there any info on setting it up or do I just set my boost safety and go. Been looking into it but not to much map 8 info out there.
as per my personal experience
With Single turbo setup, and as per my logs & their settings i just revised for you..
map 8, 10cm , and set meth additive to 30 to 35
should get around 18 psi for additive 30 and 20 psi with additive 35.
set your boost safety to 23 or 25
higher than 20 psi.. you need to upgrade fuel system as you stated.. or do a dual nozzle setup.. with dual nozzles running 10cm + 10cm you can reach additive 55 = 26PSI.
set
Meth trigger = 1
Meth safety =3
so it works on map 8
all settings and figures above are from my 3 year personal experience with Single turbo setups, and worked fine for me and our local N54 guys
you should be good to go.
2008 335i N54 FFtech Top Mount single turbo Precision 5862
JB4 G5 , VRSF 7" FMIC , VRSF CP + HKS BOV, Tial Wastegates
BMS METH KIT IN CONJUNCTION WITH MMP PI WITH 1055CC INJECTORS, PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. CUSTOM TUNE, xHP Stage2 v1.5
more to come...
