Jeevin12 Jeevin12 is offline
Default 06-15-2018, 07:22 AM
Originally Posted by Vorsprung_CJB
Before you commit to the cost and labor for a whole engine, may be worth doing a comp/leak test, change oil and get Blackstone analysis, check filter for metals, etc. Maybe check each piston with a boroscope or something. Suppose it depends on your budget and time.
im 100% that i have bad compression in one of my cylinders, I moneyshifted loool...... I went from 3rd to 2nd instead of 4th at around 5500 rpm
I just don't know if its a better idea to get a used engine, or try to rebuild this one because I could rebuild this one better than a used engine... with forged rods and pistons and a used head off ebay.
