Thread: HPFP swap
Car: M135ix
Default 03-03-2019, 06:59 AM
in the first two pictures you can see the cutaway of the evo flange it has to clear the vacuum pumps body , the orientation of the two slits where the bolts go in , follow the hexagonal shape of the pump . they are rotated 60 degrees CW compared to the evo . it allows a few degrees of play as your fuel line connections have rounded shapes . the easy way of doing it is with a 2nd vacuumpump to do your measurements and final adaptation of the two holes . do you take away just enough material as you can see on my pictures . dont rush , this take your time
M135i PWG , FBO , PS2 , LPFP st2 , HDP6 custom for N55 , wedge MHD mapping , XHP AT8
