Stoolz Stoolz is offline
Car: 11 135i
Default 09-19-2018, 11:31 PM
Originally Posted by houtan
Do you have issues if you run the stock flash with no jb4?
I have the issue no matter what, even completely stock. No jb4 no mhd. With jb4 i could make a 1 psi map 6 and still have the problem.
I spoke with my mechanic, even tho hes at his give up point he doesn't believe its my engine or trans mounts.
