Stoolz Stoolz is offline
Car: 11 135i
Default 09-01-2018, 10:52 PM
Weird codes that dont make sense, ecu fueling and knock but logs show all is fine and the car isn't actually knocking.
We have now swapped the crank angle sensor and the problem is actually worse. I think it's open circuit code (but it isn't open circuit and the wiring harness looks fine. I'm the Aussie dude who emailed you, we decided to push my car off a cliff lol!
