Goodfella Goodfella is offline
Car: Q50
Default 91 octane and e85 blend logs - 09-07-2019, 03:51 PM
Can I get some feedback on my logs? Some help would be much appreciated! Currently running 91 fuel with a e85 blend. These logs were all done on 10 gallons of 91 and 3 gallons e85 blend (used a e85 cal to convert) for about e30 blend. These logs were done on 3rd gear at 3000 rpms to wot. From what I can see my afr keeps jumping from 14.5 area all the way to 25... was told it could be because the fuel injectors arenít firing off and causing it. Wanted to double n check with the pros and hopefully get some help out on what can be done to balance this out if anything is possible at this point? Was hoping to get my down ***** installed but wanted to check on this first before making that move. Map 5 and map 6 posted.
