(#2374)
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 07-14-2019, 10:05 AM
Can you get a log so we can check it out? What map and fuel are you using?
I've attached 2 logs; I started each log between 2k and 3k rpm in 2nd gear. I'm running map 3 with e30.
I don't know if this would have any affect, but when I uninstalled the fuel wires the first time around, I noticed a few of the internal wire strands had been pinched off when screwing/unscrewing them in; I ended up just reinstalling them as is. Should I cut the wire down so all internal strands are still intact? Does this make sense?
Thanks.
