You need to adjust your duty biases manually since wastegate adaption is disabled. Once those are dialed in, then you can start cranking up the boost as you're not going to make that kind of power on map 2.
JB4 Duty Bias FF Tuning Info - N54Tech.com - International Turbo Racing Discussion
