israelg48 israelg48 is offline
Car: 2018 BMW X5 50i
Default Log Review- 2018 X50i - 05-01-2021, 10:03 AM
Hi all, I’d appreciate your input.
On auto sports shift and S or S+ (Not comfort or eco) up shifts are rough and hesitant. As if I were to let off the pedal for a microsecond and boost dropped, then spooled back up. It’s less apparent st WOT than just normal-fast driving. Not present
I see throttle dropping after shifts, sometimes significantly. Ignition also.
Current settings are standard excerpt for wastegate. Moving that around doesn’t change the issue.
Spark plugs are brand new and I’m waiting on de coils. Running 91 octane.
Edit: running map2. Smoother than map1. Changing map 1-2 doesn’t change the issue either.
Thanks in advance!
