Car: M550i
Default 05-18-2022, 12:49 PM
Originally Posted by zse8h
Boosted- would you mind sharing your map 6 settings, please? I am still not to comfortable running map 2 even though it's godly fast. Also, what is stock psi? 14-15?
Thanks in advance.
Zach
There isn't actually a stock psi as it will change all over the world with the conditions. With cool air and low altitude on 93+ fuel I would expect 12-13psi at 5000rpm peak based on my own logs.
I get the best dragy times with +5psi tapered up as not to generate too much torque at lower rpm.
My fuel is 94 with a little splash of boostaine for safety.
