(#376)
ricecrackers101 ricecrackers101 is offline
Car: 335xi
Default 05-21-2016, 01:42 PM
Originally Posted by weebles
You're running 19 psi on pump gas? I can't even get close to that with just pump (94 e10) I drop all my timing around 17 psi on pump. I'm running 70 additive on map 3 right now and the car is an absolute monster, loving it so far.
are you using petro ultra 94? how much boost do your logs show with meth? does it taper way down towards redline like it does with stock turbos or does it hold boost to redline.
