str8shot str8shot is offline
Car: N54 135i
Default 11-25-2015, 03:19 PM
Have a new display I'm trying out. This will work in conjunction with JB4 and or bluetooth (the previous display used the same voltage output as JB4).
The previous display read analog voltage in .01 increments for each percent of ethanol. For example - 1 percent ethanol would read as .01 on the display, 50% ethanol would read .50, etc.
This particular display uses a digital input, to display an exact reading from the sensor. Because of this, it doesn't suffer from any inaccuracies due to voltage fluctuation.
It's a little bit larger, and a few dollars more, but should provide for much more reliable readings.
This is compatible with any of the ECA's I've sold using three of the four twisted pair wires I had added that were reserved for future use, along with a new firmware that can be loaded via USB.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
