(#192)
Default 07-13-2018, 01:26 PM
Originally Posted by kokoN63TU
What about the Thrutel ?
When you raise boost it close
And the graph getting to 5,800 rpm
Btw my friend
You promised to do dragy run 100-200 kmh
Can’t wait to see
Throttle is as mapped from the factory and with all EWG integrated tuning remains in use to regulate boost on target. Since the throttle blade is so large relative to its inlet piping depending on the RPM it would have to close 40-50% before it starts to effect manifold boost/power. We normally dampen it in the back end flash maps not because it adds any power but because customers are trained to believe it's a problem and it's easier to change it than to continually explain that it's not.
