sir_riel sir_riel is offline
Car: q50
Default 08-18-2020, 08:19 AM
When the FW are on, your AFR will stay VERY level in the low 12 range, depending on octane, but it won't move around over a point and drop down into the 10's. For timing only look at ign 1.
thanks bro I appreciate it. you are correct about which log had fuel wires on or off. I rechecked the jb4 app, just updated the OP with the correct logs.
BTW, what values should be good or safe ignition timing values?
