(#39)
Default 10-04-2019, 10:26 AM
Originally Posted by Fred V
With the new maps now supporting meth, how would one go about setting this up? Which injection settings should we use for each maps? Des the tune do everything automatically?
I also can't find a kit for Porsches on your website, is it the same kit that you sell for bimmers? How safe is it mechanically, not accounting for possible leaks?
If you're mechanically inclined you can do the install yourself.
We're working on a PNP kit with a chargepipe for 1/8npt port.
If you don't want to wait, you'd have to drill into your stock stuff for that.
Methanol injection with the JB4/FSB integration is the safest option you can get! We have safety implementations programmed into the JB4 to keep the engine safe and happy. The JB4 can revert to stock mapping if it see's AFR too lean, fuel trims maxed out, no methanol flow, etc
