Joelkswagen Joelkswagen is offline
Default 09-12-2019, 04:36 PM
The timing flat line / corrections imo are likely octane related, possibly old plugs, although if swapped 10k ago- that isnt extremely old- which plugs are you using?
You could throw a bit of ethanol in there 2-3 gallons, and see if that cleans up the timing
Thank you Dave! I will run some logs with some E added to the tank, and report back. I also ordered the recommended NGK plugs.
