Stoolz Stoolz is offline
Car: 11 135i
Default hpfp oscillating - 07-23-2019, 09:40 PM
Hi brains trust.
Anyone know why my hpfp is oscillating like crazy?
It's not lpfp. I have them powered up direct and enough lp for 1000whp. Its not the fuel lines either they are all new, as is the hpfp.
As you can see afr follows it.
Don't know why the ECU would be doing this if that's the case.
My car has had an issue for YEARS now, might be tracking it down now I hope.
Cheers,
