naoaki's Avatar
naoaki naoaki is offline
Default Twin solenoid math - 10-19-2018, 04:50 PM
Hey, guys I am using direct port meth. I also have a 7th injector. I thought that if you separated the 7th injector from the direct port system and placed it using another solenoid, it was released from the 7th long piping and the reaction speed could be improved. The point I care about is whether the FSB can provide enough voltage to properly move the two solenoids. Does anyone know an example of using two solenoids with FSB? Thanks in advance for all the responses in advance.
BMW 2007 E90 335i
JB4 G5 IOS MHD race flash MMP High flow aluminum intake MMP Hot side inlet Down pipe Outside intercooler Twin oil cooler cp-e charge pipe BMS meth kit turbo lab stage 1 turbo CSF radiator fuel-it stage 1 pump
