Do you have a log? So you do a pull and the car shuts off?
I do but I can tell you nothing is in the log to identify the problem.
There is a little hiccup in 02 but that is because of the violent shutdown.
The logs are immaculate, all parameters perfect.
The car has been logged with both jb4 and mhd many many times.
It's just crazy , that crazy I've decided to post here about it in case anyone has ever seen anything remotely like it.
Thanks for the response!!
