Thread: Map 6 Pull
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 11-25-2021, 08:56 AM
Assuming pulls were at full throttle log looks fine (Pedal position is showing like 75, but throttle is showing 100).
That is a very conservative map for a non RS model. I would just use the stock maps provided by BMS. They do taper and your ECU boost tapers as well so you won't be over boosting at high RPM. Try Map 2 and post back. Make sure 100% throttle all the way to redline if you can safely.
