ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 02-12-2016, 08:44 AM
I had a misfire show up in cylinder 5, ironically it first happened when I was running a 991 GT3 on the way to Cars & Coffee in Aliso Viejo (we were neck and neck). Coils are brand new Delphis, plugs are low mileage NGK 5992s, Cyl 5 on the left Cyl 6 on the right. Interestingly I swapped the plugs and coils and the misfire is still on cyl 5, I have not checked the injector yet but it is a -12 with maybe 1,000 miles on it so it SHOULD be fine.
Some more goodies for the 6MT swap arrived, a big thank you to the companies who are contributing to this build.
MFactory SMFW
Spec Stage 3+ Clutch
BMS SSK and DSSR
N54 Powered M5 Wagon:
