(#34)
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 01-20-2015, 03:14 PM
Terry, doesnt the aic4 run off two maps? tach and map? could it run off tach alone? and at what boost would you prefer it to go to since 26 isnt enough?
