logle logle is offline
Default 01-12-2016, 07:11 PM
Hey, Ive got the same codes on my DME - 2ACC and 2ACB and the Car will not turn over. Not sure the DME would cause this but appears the DME also needs work. Can you describe how you fixed this? my car is a build date 11/06, DME number is 07611397
A little background, the lead to my water pump rubbed against the exhaust manifold and melted frying parts of the wiring harness, several sensors and the water pump. I've replaced the wiring harness, CAM sensors and Vanos solenoids. Also new water pump and thermostat. I open the door and the red steering wheel lock illuminates and the steering wheel is locked. Inserting the key does nothing to unlock the steering wheel. All other electronics seem fine but the steering will not unlock and the car will not start. Any ideas?
