(#596)
Snowman Snowman is offline
Car: BMW M135I
Default 04-27-2018, 12:09 PM
Trims should fall between 0 (-33%) and 50 (+33%) to avoid effecting AFR targeting.
In that case it is very interesting that this user experienced his trims to fall from 30-35
http://www.n54tech.com/forums/showpo...&postcount=598
To 5-10 WOT
http://www.n54tech.com/forums/showpo...&postcount=596
First link is before BEF and second after/with your race BEF.
It even shows signs of running "lean" when trims are hitting 10-11.
So if what you wrote is correct there must be an issue with the BEF you are providing..
