(#4443)
jayhawk91 jayhawk91 is offline
Car: Infiniti Q50
Default 07-22-2019, 03:40 PM
Recently installed the $300 BMS Heat exchanger and the car seems to be running better in the heat (close to 100 today). Trans temp in the afternoon is about 113-118 cruising. Did a low 3rd gear pull to WOT and the car got up to 130 before coming back down. Is this what I should be expecting from the heat exchanger? I have logs attached, running Map 5. Thanks!
