Thread: map 7 log
JBoe JBoe is offline
Car: M240i
Default 04-07-2019, 03:54 PM
It's not too bad. Looks to me like you're over driving the fuel as your trims are low. The B58 likes to be above 30 and below 45 from my experience. I also see that you have a few settings set to other than default that generally don't need adjusted. (Boost Safety, PID, Auto Boost Reduction, etc.) Lastly, your still creeping a bit high on boost in the upper RPMS and may need to trim the bias down a bit more to keep from the closures occurring. Your FF is very low... this is showing that your boost is going high and it's trying to trim it down. If you run too low on FF, it can't keep control very well. Otherwise, it's not a bad looking log. Others can comment, but this is what I see. Hope this helps.
