Thread: E85 question
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 08-25-2015, 06:00 PM
Originally Posted by obriennathaniel
correct, i guess i could have worded that a little different. It allows you to adjust your timing so you could possibly add more boost, considering all the variables are in the correct range.
I see. The reason I thought this might not work on EWG is because we don't use power and ground wires.
Would I see any benefit from the turbo timing trick if I'm stock turbo on E40?
Sorry, I'm a noob :p
