Philly_tee Philly_tee is offline
Car: C400
Default 03-29-2021, 09:10 PM
@gimmefunk ugh, I’m having the same issues right now. No boost on my c400 only when I hammer it then the boost comes on for a second or so. Logs are showing 0 target and then going up very slowly. I’m going to reconnect wires, double check and reinstall. If that doesn’t work I’ll uninstall and use a multimeter on every wire.
You replaced the entire red wire on the harness?
