(#39)
Default 06-18-2019, 02:10 PM
Originally Posted by TSI 1.8T Jasper
ok so just did what you asked , car was up to temp after drive from work ..with stock MAP sensor cable plugged in car has no hiccups at all once JB4 MAP cable gets plugged back in hiccups are back. I can say that they are lot less obvious with the firmware update but unfortunately do exist , as long as no harm im not to concern since they are very small but if you have a fix that would be fantastic.
OK that is what I wanted to know, so it's definitely related to the brown connector signal?
