TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 07-17-2019, 11:45 PM
I'm just wondering as well, the LOAD as logged by the JB4 seems quite low.
I'm tracing the timing table in the BEF using TunerPro and the load values in my log seem very low.
Load value of 18 at 20psi seems a bit low? Timing is around 8-9 degrees between 4-5000 RPM which would assume load values around 140+ right?
Do I multiply the logged load value by 10 or something? I couldn't see this in the logging parameters guide.
Sorry if I'm way off here.
I'll post my logs once I get some clean pulls in, wet weather has meant no traction recently!
