emlevins emlevins is offline
Car: 2014 BMW 335xi F30 N55
Default Thoughts and Advice please on RPM variability and mechanic's explanation - 06-22-2021, 10:30 AM
Hello - I have a Jb4 for a 2014 BMW 335xi F30 N55. No problem with it for 2 years. Had one on my 07 E90 for many years with no problem. I am a set it to map 1 and leave it guy. I am mechanically uninclined and my knowledge in this area is very limited so simple explanations or suggestions without shaming would be appreciated 😉.
I recently starting experiencing extreme rpm variability upon startup. Engine will race then almost stall, race, etc. This lasts for about a minute then it smooths out and car runs fine
Took the car to a local shop. I did not switch map from 1 to 0. He unplugged cable from obd port to check codes and got a code for the monitoring system (?). He did tuneup and found the plugs were a mess. He replaced them. Car did the same thing, and found new plugs were now fouled. He replaced them a second time. He disconnected Jb4 and reconnected things as they were as Oem. He said car runs fine.
He told me that there is power going to monitoring system but not out of the monitoring system to the Jb4. Hence, he says Jb4 is not getting power and problem is with monitoring system.
Thoughts?
Does this make sense?
Is the Normal setup for the JB4 to connect to monitoring system for power?
Does the rpm problem at setup sound like anything that would be JB4 related ( I was thinking perhaps the map setting was changed accidentally or something?). Thanks in advance for your help.
Any help would be appreciated. Thanks.
Sent from Yahoo Mail on Android
