zort zort is offline
Default Suspension knock - 08-01-2018, 11:51 AM
Hey Guys,
I need some guidance understanding the front suspension of a 2007 e90. On normal roads with pot holes etc there is no problem. However once I make a sharp right into the driveway you hear a knock once the wheel dips for the drain.
I don't understand why this would not happen with regular holes not turning.
All the same I check the suspension and all seems fine however since this is only happening on a turn where should I be looking specifically.
Thanks in advance.
