Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 04-19-2019, 01:32 PM
Originally Posted by tylerd
I dont plan on going the meth route and also its just going to be pump gas for me
So a larger intercooler should hopefully make up for that in a way.
Normal temperatures here in germany are quite low, with minor peaks in the summer. Not taking it to the track either.
Also I would prefer a clean solution, where the fitment and parts that are coming with the IC are great. If I need to build custom brackets to make it work, then thats a deal breaker.
Never really had CSF in the equation, gonna read up on them!
Anyone else with an opinion/advice , maybe?
Something also to consider is drag racing. If you are sitting in staging lanes you will get a lot of heat soak before your run. If you don't drag race then I think a larger intercooler will serve you fine. All of the intercoolers that are built for your can shouldn't need special brackets. If you want to run a 7 inch intercooler you will need to cut away some of the plastic.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
