(#69)
rhylea's Avatar
rhylea rhylea is offline
Car: BMW 335i N55
Default 10-29-2016, 02:55 PM
"We don't have this issue on the MHD flash only map, because those contains only the tuning tables and are applied on top of the proper OEM, region specific map.
But since the BMS maps are canned US bins, some settings do not apply for non US specs cars. Disabling some codes such as DMTL is already doable though. What codes are popping up?"
These are the codes that show up.
3224 = P240A - Evaporative Emission System Leak Detection Pump Heater Control Circuit/Open - DMTL heater
321B = P2418 - Evaporative Emission System Switching Valve Control Circuit/Open - Switching Valve
3227 = P2400 - Evaporative Emission System Leak Detection Pump Control Circuit/Open - Pump
AUS 2011 - E92 - 335i - N55 - DCT - MSport
JB4 + FF Wires | MHD N55 BMS E85_PI BEF | aFe Power Magnum Stage 2-Si air intake | BMS Charge Pipe | Magnaflow 3-inch rear mufflers | NGK 5992s Gapped To 0.018"
Daily driven Map 7 running E85 at 55% | Settings: FW 5.16, DWP 60, PID Gain 25, FOL 90, WGA 80, Boost Safety 21
