Default JB4 for 2018+ AUDI RS3 & TTRS - 12-01-2018, 11:38 AM
Order here: http://www.burgertuning.com/vw_volks...Jb4_tuner.html
We'll use this thread for our upcoming Audi RS3 & TTRS JB4 SENT BETA updates, map guides, firmware, and discussion!
Install Guide here: http://www.n54tech.com/flash_files/audi_s4_install.pdf
Optional map changing, datalogging and updates are done using the BMS data cable or JB4 Mobile REV3 bluetooth kit.
BMS data cable hard wired directions and software Click here
Map guide as of v4 firmware:
Map0: Stock tuning, disable JB4
Map1: (default map) 2psi peak over stock
Map2: 3psi peak over stock
Map3: 4psi peak over stock
Map4: 5psi peak over stock
map5: 6psi peak over stock
Map7: Integrated WMI (water/meth) map, progressive control with boost increased as a function of fluid flow up to the user defined WMI additive.
Map8: Valet/Low Boost/Safety map. Runs 25% less boost than stock.
Dragy results:
10.8s all stock on JB4+E30: N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 for 2018+ AUDI RS3 TTRS
Firmware:
JB4_AUDI_TTRS_5:
1) Adjusted map5 to target up to 7.5psi over stock, for those running E30 or unleaded race gas who want to push things a bit. Results in around 22psi in most situations.
2) Adjusted shift boost reduction logic to further reduce boost spikes during shifts. Default setting is shift reduction = 50. A higher value will reduce boost more during shifts and a lower value less.
3) Minor adjustments to boost ramp in to improve operation under boost limiting/loss of traction situations.
4) Added support for low fuel pressure hardwire connection to monitor and rescale, allowing some fuel trim reduction in heavy E85 mixtures. Requires harness addition so is just under testing for specific cars for now.
JB4_AUDI_TTRS_4_T3:
1) Various minor map and tuning revisions.
JB4_AUDI_TTRS_3:
1) Revised boost targets per map
2) Added direct boost control logic allowing dramatically more boost than is possible previously. Enabling this unique feature requires purchasing the optional BCM module.
3) Revised logging channels to include high fuel pressure on a scale of 0-50 = 0-3000psi.
4) Revised logging channels to add road speed
5) Added in over boost and lean-run JB4 safety systems. If boost exceeds user adjustable "boost safety" setting for more than 1 second the JB4 will switch to map0 (disabled). If AFR goes leaner than 15:1 at full throttle for more than 1 second the JB4 will switch to map0 (disabled). More advanced user adjustable safety systems including the ability to failsafe to less boost than stock (for flashed cars) is under development.
JB4_SENT_AUDI_RS3_1:
1) Adjusted warm up temperature safety to avoid bug with it kicking in when car is heated up.
2) Adjusted cyl 2-5 logging parameters so they show much higher values, to make boost/octane evaluations easier.
3) Created a firmware split so "S4" firmware will be used for all six cylinder models, and "RS3" firmware for all five cylinder models.
FutureUseD Bit Settings as of v3 firmware:
Bit0:
Bit1:
Bit2:
Bit3:
Bit4: Turn on to disable JB4 passive safety systems (over boost safety, lean run safety)
Bit5: Turn on to disable extended Audi logging channels (knock 2-5, dme bt, ecu_psi, fp_h, gear). Disabling these channels doubles the sampling speed of the primary channels.
Bit6:
Bit7:
Default BCM settings:
How to update firmware via JB4 Mobile:
