(#42)
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 09-17-2018, 04:14 PM
Timing should be around 12 deg up top? You think there is some knock?
I noticed my ff is climbing too after the two pulls. Ive left the duty bias unlocked as well.
Ill do a few more pulls.
