(#3883)
Car: 2008 E93
Default 08-31-2019, 02:13 PM
Originally Posted by Rule77
Here’s a better log with e30.
Trims, AFR, Boost all appear to be in check. Main issue I see here is timing and high IATs. Timing will take a dump due to high IATs. Definitely need a better FMIC and more octane can only help. Lpfp has room for E40 most likey, not too sure about hpfp until you try it and log. I wouldnt push too hard with those IATs though personally. I would address that first, and to be on the safe side, I would lower boost until you do so. Thats IMO. You could throw some logs up in support section for more feedback from others.
