(#3882)
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 08-31-2019, 10:34 AM
Logs are a little short. I would like to see to redline BUT, it looks fine to handle e40 if these are on E30. I would probably flash E85 map. Your trims are fine now, a little high, but will climb higher with more ethanol. Make sure you log to check hpfp.
Heres a better log with e30.
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5 RACE FMIC
VRSF DPs - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19 666m WHEELS - HANKOOK VENTUS V12 EVO 2s
