ManiN54's Avatar
ManiN54 ManiN54 is offline
Car: 2007 335i FBO stock turbos
Default 04-28-2019, 10:13 AM
I would go on a limb and say injector #6 is your culprit, at least one of the problems. That code 2e35 is very straight-fwd; it’s normally bad injector or bad connection to the injector. 29D0 could be a result of a bad coil/spark plug/ bad connection to coil, vacuum leak etc. other two codes resulted from these two.
1/4mile 11.8@117.96 19psi
07 E92 335i (the Alpträum) | Alpine wht/ Seibon carbon hood/ trunk| M parallel wheels| street tires
FBO| modified oem airbox lid w/K&N drop-in| stock turbos/ stock inlets| Walbro 465lph LPFP| Jb4/mhd backend flash| Map 6 w/E60 No Meth| Built and tuned by me.
