(#763)
lllN54lll's Avatar
lllN54lll lllN54lll is offline
Car: 335i N54
Default 05-31-2017, 09:14 AM
Originally Posted by MHD
- Added "Remove top speed (VMAX) limiter" flash option
- Added "OEM/catted ***" flash option
- Added DME fault codes history
The open speed limiter settings were not working on all cars. Now it should! And rather than baking it into the maps, we implemented it as flash option, so it can be used on any map, OTS maps of course, even stage 0, custom tunes, or BMS maps.
Will the deactivation of the Vmax work at the last JB4 BEF? Or you only changed it for MHD Maps? (For cars where it does not work before)
@Terry
Do I need a DP fix for the BEF or it is disabled at this files?
