(#761)
Stoolz Stoolz is offline
Car: 11 135i
Default 05-30-2017, 01:31 PM
Originally Posted by jturboawd
@ Stoolz, just watch out for full pump crashing. I still get some crashing at high PSI on straight e85. I have had to play with the tune, specifically the load ceiling, to keep it from happening. If it happens to you, look at the load ceiling but also consider moving to a pump to e85 blend. I have been putting 3 gallons of 93 in each fill to make it easier on my hpfp.
So even with PI the hpfp still has issues?
That's a bummer, I really wanted to run straight E85.
Thanks for the advice.
